Introduction
The CPU processor is the part of your device that handles multiple tasks and processes at once. If you need to replace the CPU of your HP Z2 Mini G3, follow this guide.
Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm you.
Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
Remove the 9mm Torx screw with a T15 Torx screwdriver to release the SSD assembly.
Lift the assembly upwards to remove it.
