Introduction
The power on/off and HDD activity LED indicates whether the HP Z2 Mini G3 (Model No. 1LE81UP#ABA) is on or off. Also, the HDD activity LED supports as an indicator for hard drive operation.
Follow safe cable practice while handling the cables and keep them away from heat sources.
Be sure that the power is off and the A/C power cord has been disconnected before working on interior components. Removing hardware while the power is on could damage the device or harm you.
Components inside the device are also subject to static damage, so try and work on a hard surface to reduce this risk.
Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
Remove HDD activity LED from retaining clip.
