Aller au contenu principal
HP ZBook 15u G2 Heatsink Replacement
Ce dont vous avez besoin
  1. HP ZBook 15u G2 Heatsink Replacement, Battery: étape 1, image 1 de 1
    • Turn the HP Zbook over and flip the switch at the top so the red part is visible.
  2. HP ZBook 15u G2 Heatsink Replacement: étape 2, image 1 de 1
    • Pull the back cover down to remove it.
  3. HP ZBook 15u G2 Heatsink Replacement: étape 3, image 1 de 2 HP ZBook 15u G2 Heatsink Replacement: étape 3, image 2 de 2
    • Flip the two switches on the top of the battery so the red is visible.
  4. HP ZBook 15u G2 Heatsink Replacement: étape 4, image 1 de 1
    • Lift the plastic tab at the top of the battery up to lift the battery up and out of the device
  5. HP ZBook 15u G2 Heatsink Replacement, Heatsink: étape 5, image 1 de 2 HP ZBook 15u G2 Heatsink Replacement, Heatsink: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a torx 8 screwdriver to remove the 11 M2.5x5mm torx screws labeled M2.5x5.
    • Use a pair of tweezers to remove the rubber feet at the edges and corners of the laptop to reveal the other 8 torx screws and remove them as well
  6. HP ZBook 15u G2 Heatsink Replacement: étape 6, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the five M2.0x2 mm screws beneath the battery.
  7. HP ZBook 15u G2 Heatsink Replacement: étape 7, image 1 de 1
    • Remove the 4 mm Phillips screws under the SD card slot on the left of the laptop.
    • Lift the plastic edges around the bottom of the laptop to remove the bottom plastic cover.
  8. HP ZBook 15u G2 Heatsink Replacement: étape 8, image 1 de 2 HP ZBook 15u G2 Heatsink Replacement: étape 8, image 2 de 2
    • Loosen the 2 silver Phillips screws on the fan assembly.
    • Remove the 6 Phillips screws at the left side of the heatsink assembly.
  9. HP ZBook 15u G2 Heatsink Replacement: étape 9, image 1 de 2 HP ZBook 15u G2 Heatsink Replacement: étape 9, image 2 de 2
    • Using tweezers, gently unplug the wire the connects the fan to the motherboard.
  10. HP ZBook 15u G2 Heatsink Replacement: étape 10, image 1 de 1
    • Grip the heatsink assembly by the fan and lift it up to remove it.
    • Use computer duster to blow away and remove any dust and particles in and around the heatsink and fan assembly.
Kwasi Sarfo
Membre depuis le 03/13/23
285 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-5, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 3-5, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G5
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 222
