Aller au contenu principal
HP dv5-1125nr Battery Replacement
Ce dont vous avez besoin
  1. HP dv5-1125nr Battery Replacement, Battery: étape 1, image 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Battery Replacement: étape 2, image 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 autres ont terminé cette réparation.
Nick Loey
Membre depuis le 04/01/14
1 688 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 9-15, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 membres
10 tutoriels rédigés
2 commentaires
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - Réponse
what is your return policy?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,197
