Aller au contenu principal
HP dv5-1125nr Disk Drive Replacement
Ce dont vous avez besoin
  1. HP dv5-1125nr Disk Drive Replacement, Battery: étape 1, image 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: étape 2, image 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: étape 3, image 1 de 2 HP dv5-1125nr Disk Drive Replacement, Disk Drive: étape 3, image 2 de 2
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: étape 4, image 1 de 3 HP dv5-1125nr Disk Drive Replacement: étape 4, image 2 de 3 HP dv5-1125nr Disk Drive Replacement: étape 4, image 3 de 3
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
Nick Loey
Membre depuis le 04/01/14
1 676 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 9-15, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 14
Total : 733
