Aller au contenu principal
HP dv5-1125nr RAM Replacement
Ce dont vous avez besoin
  1. HP dv5-1125nr RAM Replacement, Battery: étape 1, image 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr RAM Replacement: étape 2, image 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr RAM Replacement, RAM: étape 3, image 1 de 1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr RAM Replacement: étape 4, image 1 de 2 HP dv5-1125nr RAM Replacement: étape 4, image 2 de 2
    • Remove the RAM cover to reveal the module's underneath.
  5. HP dv5-1125nr RAM Replacement: étape 5, image 1 de 3 HP dv5-1125nr RAM Replacement: étape 5, image 2 de 3 HP dv5-1125nr RAM Replacement: étape 5, image 3 de 3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
3 autres ont terminé cette réparation.
Nick Loey
Membre depuis le 04/01/14
1 676 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 9-15, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 971
