Aller au contenu principal
HP dv5-1125nr WLAN Card Replacement
Ce dont vous avez besoin
  1. HP dv5-1125nr WLAN Card Replacement, Battery: étape 1, image 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr WLAN Card Replacement: étape 2, image 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr WLAN Card Replacement, Hard Drive: étape 3, image 1 de 2 HP dv5-1125nr WLAN Card Replacement, Hard Drive: étape 3, image 2 de 2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr WLAN Card Replacement: étape 4, image 1 de 1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr WLAN Card Replacement: étape 5, image 1 de 2 HP dv5-1125nr WLAN Card Replacement: étape 5, image 2 de 2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr WLAN Card Replacement: étape 6, image 1 de 2 HP dv5-1125nr WLAN Card Replacement: étape 6, image 2 de 2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr WLAN Card Replacement: étape 7, image 1 de 2 HP dv5-1125nr WLAN Card Replacement: étape 7, image 2 de 2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr WLAN Card Replacement, WLAN Card: étape 8, image 1 de 1
    • Locate the wireless card and the two wires attached to it.
    • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
    • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
  9. HP dv5-1125nr WLAN Card Replacement: étape 9, image 1 de 2 HP dv5-1125nr WLAN Card Replacement: étape 9, image 2 de 2
    • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
  10. HP dv5-1125nr WLAN Card Replacement: étape 10, image 1 de 2 HP dv5-1125nr WLAN Card Replacement: étape 10, image 2 de 2
    • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
    • The card is now free from your computer.
Cory Mayer
Membre depuis le 04/01/14
879 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-15, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 1,148
