Aller au contenu principal
HP dv7-4065x Keyboard Replacement
  1. HP dv7-4065x Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Remove the battery from the laptop.
  2. HP dv7-4065x Keyboard Replacement: étape 2, image 1 de 1
    • Move the switch in the battery compartment.
  3. HP dv7-4065x Keyboard Replacement: étape 3, image 1 de 1
    • Carefully flip up the keyboard panel.
    • Don't pull far on the keyboard. It will still be connected to the laptop via ribbon cables.
  4. HP dv7-4065x Keyboard Replacement: étape 4, image 1 de 1
    • Lift the retaining flap on the keyboard cable ZIF connector.
    • Carefully pull the ribbon cable from its socket on the motherboard.
Mikayla Tabora
Membre depuis le 03/08/17
201 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G1, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S3-G1, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G1
3 membres
4 tutoriels rédigés
Un commentaire
First you need to unscrew 2 screws under the HDD cover
christo04 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,599
