Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP iPAQ H2200 Joypad Replacement
Ce dont vous avez besoin
  1. HP iPAQ H2200 Joypad Replacement, Battery: étape 1, image 1 de 1
    • Press and slide the battery cover tab to remove battery cover.
    Demander à FixBot
  2. HP iPAQ H2200 Joypad Replacement: étape 2, image 1 de 2 HP iPAQ H2200 Joypad Replacement: étape 2, image 2 de 2
    • Pull on the black tab to lift the battery out of the battery compartment.
    Demander à FixBot
  3. HP iPAQ H2200 Joypad Replacement, Main Board: étape 3, image 1 de 1
    • Remove the stylus by sliding it out of the slot.
    Demander à FixBot
  4. HP iPAQ H2200 Joypad Replacement: étape 4, image 1 de 1
    • Remove the CF card by sliding it out of the slot at the top of the device.
    Demander à FixBot
  5. HP iPAQ H2200 Joypad Replacement: étape 5, image 1 de 1
    • Press down and push the black side strips toward the top of the device to remove them.
    Demander à FixBot
  6. HP iPAQ H2200 Joypad Replacement: étape 6, image 1 de 3 HP iPAQ H2200 Joypad Replacement: étape 6, image 2 de 3 HP iPAQ H2200 Joypad Replacement: étape 6, image 3 de 3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
    Demander à FixBot
  7. HP iPAQ H2200 Joypad Replacement: étape 7, image 1 de 2 HP iPAQ H2200 Joypad Replacement: étape 7, image 2 de 2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
    Demander à FixBot
  8. HP iPAQ H2200 Joypad Replacement: étape 8, image 1 de 1
    • Open the LCD connector, where the orange strip attaches to the main board.
    Demander à FixBot
  9. HP iPAQ H2200 Joypad Replacement: étape 9, image 1 de 1
    • Carefully remove the orange LCD strip from the connector.
    Demander à FixBot
  10. HP iPAQ H2200 Joypad Replacement: étape 10, image 1 de 1
    • Unscrew the 2 screws located at each top corner of the main board.
    Demander à FixBot
  11. HP iPAQ H2200 Joypad Replacement: étape 11, image 1 de 1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
    Demander à FixBot
  12. HP iPAQ H2200 Joypad Replacement, Joypad: étape 12, image 1 de 1
    • Press on the four joypad tabs on the back, and push it through and out the front.
    Demander à FixBot
  13. HP iPAQ H2200 Joypad Replacement: étape 13, image 1 de 1
    • Push the new joypad through the hole; the tabs will lock it into place.
    Demander à FixBot
Tyler Andrews
Membre depuis le 01/13/10
209 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-12, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 72
Total : 3,404
