Pièces
Aucune pièce nécessaire.
  1. Flip the HP iPAQ HW6515 over with the screen facing down.
    • Flip the HP iPAQ HW6515 over with the screen facing down.
    • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
    • Place the back of the case aside for now.
  2. Remove the battery by pulling up on the black tab.
    • Remove the battery by pulling up on the black tab.
    • Unscrew the four screws using the T6 hexagonal star screwdriver.
    • Unscrew the middle screw using the Phillips 00 screwdriver.
    • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
    • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
    • Slide the plastic opening tool along the seam until the two halves of the case separate.
    • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
    • Gently pull off the black rubber square covering the LED light.
    • The LED is now exposed.
    • Wedge the plastic opening tool under the LED to pop it out and expose its wire.
    • Using your index finger and thumb, unplug the wire from the phone and remove the LED.
Steven Vo
Membre depuis le 02/04/2012
33 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-17, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 15-17, Forte Spring 2012
CPSU-FORTE-S12S15G17
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,043
