Outils
Pièces
Aucune pièce spécifiée.
Slide the silver release tab up and simultaneously lift the cover up from the left side.
Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
Remove the 4 screws along the bottom of the faceplate
They are #00 Philips head screws
once the joypad key have been removed use the tweezers to carefully maneuver the wire out of its clip releasing the battery
3 autre(s) ont terminé cette réparation.
Un commentaire
This guide is AWESOME.. Thanks! I have an iPAQ 1945 h1900, but this guide was the exact same for my device. I got as far as the taking the battery out without removing the 5th screw beneath the "warranty void" sticker. My only issue--do you know where to get the replacement battery?
