Introduction
The computer case houses all the internal components of the computer that are essential to its operations. Certain cases may need thumb screw removal or maybe design so that they are tedious to be taken apart, however the HP rp5700 is designed to be easily disassembled.
Tip: If it doesn't come loose, wiggle it gently.
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
11 autres ont terminé cette réparation.
Un commentaire
Thank you! It's easy once you know how to do it, but I was stumped trying to figure it out.
