Introduction
The Optical Drive is the technical term for a CD drive. This is the component that reads the disks and transfer the information into something that we can view on a monitor.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Make sure the computer is unplugged.
  • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
  • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
  • Set the desktop down horizontally with the front side facing you.
Ajouter un commentaire
Hold the desktop with two hands by grasping both sides of the desktop.
  • Hold the desktop with two hands by grasping both sides of the desktop.
  • Press the buttons on both sides using your index fingers.
  • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
  • Lay the desktop back on the table and pull the case forward as far as it can go.
  • Lift the cover up and off.
In this step, make clear that the CPU is lifted in the air to aide in the cover separation. Cover removal for a CPU is usually the most time consuming step if not clearly outlined. Employ brevity but clarity.
Mark - Réponse
  • Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
  • Disconnect the power supply cord and the SATA cord using your hands to pull them out.
  • Using your left index finger, lift the upper green tab found on the left side of the green piece.
  • Using your opposite hand, use your fingers to push the back of the drive forward and slide it out away from the desktop.
  • Grasp the optical drive with your right or left hand and pull the drive out towards you.
    • It will help if you lay the device flat in order to remove the drive.
Alyssa Briones
Membre depuis le 21/01/2014
1 276 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 6-23, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 421
