Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
The power supply functions exactly as it sounds, it supplies power to the computer. Some components inside the computer need a direct connection to the power supply whereas others may draw power directly through their connection to the motherboard. Many power supply will have power cables that hang loss inside the case. These loss cables are there in case there are new components added to the computer that need them.
  1. Make sure the computer is unplugged.
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. Hold the desktop with two hands by grasping both sides of the desktop. Press the buttons on both sides using your index fingers.
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. Slide the top cover about an inch forward using your thumb to push it towards you. Make sure that the bottom is still secured by both hands. Lay the desktop back on the table and pull the case forward as far as it can go.
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
    In this step, make clear that the CPU is lifted in the air to aide in the cover separation. Cover removal for a CPU is usually the most time consuming step if not clearly outlined. Employ brevity but clarity.
    Mark - Réponse
  4. Using your hand, grip the Optical Drive and lift it up into a 45 degree angle. Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
    • Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
  5. Disconnect the power supply cord and the SATA cord using your hands to pull them out.
    • Disconnect the power supply cord and the SATA cord using your hands to pull them out.
  6. Using your left index finger, lift the upper green tab found on the left side of the green piece. Using your opposite hand, use your fingers to push the back of the drive forward and slide it out away from the desktop.
    • Using your left index finger, lift the upper green tab found on the left side of the green piece.
    • Using your opposite hand, use your fingers to push the back of the drive forward and slide it out away from the desktop.
  7. Grasp the optical drive with your right or left hand and pull the drive out towards you. It will help if you lay the device flat in order to remove the drive.
    • Grasp the optical drive with your right or left hand and pull the drive out towards you.
    • It will help if you lay the device flat in order to remove the drive.
  8. Using your right index finger, press the tab with the green sticker located underneath the power supply. While pressing the tab, lift up the power supply the same way you lifted up the optical drive. You lifted the optical drive by grasping it with the opposite hand while pressing the tab and pulling it outward way from the center of the device.
    • Using your right index finger, press the tab with the green sticker located underneath the power supply.
    • While pressing the tab, lift up the power supply the same way you lifted up the optical drive.
    • You lifted the optical drive by grasping it with the opposite hand while pressing the tab and pulling it outward way from the center of the device.
  9. Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
    • Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
    • Repeat the same process to remove the internal card power cable.
    • This is the same process as preformed when you previously removed the power cables from the optical drive and the hard drive.
    • Some cables may have small clips securing them in place. If so, be sure to press these clips inward using your fingers before pulling them out.
  10. Continue to rotate the power supply to a 90 degree angle pointing upward. Gripping the power supply with your hand, lift the power supply up to remove from the desktop.
    • Continue to rotate the power supply to a 90 degree angle pointing upward.
    • Gripping the power supply with your hand, lift the power supply up to remove from the desktop.
5 autre(s) ont terminé cette réparation.
Alyssa Briones
Membre depuis le 21/01/2014
1 564 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 6-23, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 membres
9 tutoriels rédigés
Thank you so very much for this manual! Very clear and easy to understand! Keep up the good work! Much appreciated!
jan 2332 - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 2,184
