Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Are you unable to adjust the sound on you HP w2216h monitor? You may need to replace your control buttons. These buttons are responsible for sound adjustment, calibration, input selection, and more.
  1. Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
    • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
    • Remove the four 12 mm Phillips #000 screws on the back panel.
  2. Remove the two 12 mm Phillips #000 screws above stand mounting bracket. Using a Phillips #1 with the 150 mm flexible extension  remove 1 Phillips #1 screw under the stand mounting bracket.
    • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
    • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal. Turn monitor so that the screen is facing you. Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. Lift the screen assembly from the plastic housing from the corners.
    • Lift the screen assembly from the plastic housing from the corners.
  5. Remove the plastic buttons from the contacts
    • Remove the plastic buttons from the contacts
  6. Remove the wire connecting the contacts to the screen assembly. Remove the wire connecting the contacts to the screen assembly.
    • Remove the wire connecting the contacts to the screen assembly.
Patrick Aucoin
Membre depuis le 25/03/2016
221 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-1, Miles Spring 2016 Membre de l'équipe UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 160
