Aller au contenu principal
HP x2 10-p010wm Battery Replacement
Ce dont vous avez besoin
  1. HP x2 10-p010wm Battery Replacement, Battery: étape 1, image 1 de 1
    • Pull the screen away from the keyboard.
  2. HP x2 10-p010wm Battery Replacement: étape 2, image 1 de 2 HP x2 10-p010wm Battery Replacement: étape 2, image 2 de 2
    • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
  3. HP x2 10-p010wm Battery Replacement: étape 3, image 1 de 1
    • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
    • Do not pull up too hard; slowly slide it towards the screen.
  4. HP x2 10-p010wm Battery Replacement: étape 4, image 1 de 1
    • Remove the eight 4mm Phillips #00 screws from the metal plate.
  5. HP x2 10-p010wm Battery Replacement: étape 5, image 1 de 3 HP x2 10-p010wm Battery Replacement: étape 5, image 2 de 3 HP x2 10-p010wm Battery Replacement: étape 5, image 3 de 3
    • Slowly peel up any tape securing the wire to the metal cover.
    • Remove the metal cover to access the battery.
  6. HP x2 10-p010wm Battery Replacement: étape 6, image 1 de 1
    • Remove the 4mm screw on the side.
  7. HP x2 10-p010wm Battery Replacement: étape 7, image 1 de 1
    • Remove the black tape.
    • Pull the battery connector towards the battery to disconnect it from its socket.
  8. HP x2 10-p010wm Battery Replacement: étape 8, image 1 de 1
    • Remove the battery.
Vinh Phan
Membre depuis le 10/30/19
310 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S4-G3, Saloman Fall 2019 Membre de l'équipe UMass Dartmouth, Team S4-G3, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 16
Total : 422
