Aller au contenu principal
HP x2 10-p010wm Screen Replacement
Ce dont vous avez besoin
  1. HP x2 10-p010wm Screen Replacement, Screen: étape 1, image 1 de 2 HP x2 10-p010wm Screen Replacement, Screen: étape 1, image 2 de 2
    • Pull the screen away from the keyboard.
  2. HP x2 10-p010wm Screen Replacement: étape 2, image 1 de 2 HP x2 10-p010wm Screen Replacement: étape 2, image 2 de 2
    • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
  3. HP x2 10-p010wm Screen Replacement: étape 3, image 1 de 1
    • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
    • Do not pull up too hard; slowly slide it towards the screen.
  4. HP x2 10-p010wm Screen Replacement: étape 4, image 1 de 3 HP x2 10-p010wm Screen Replacement: étape 4, image 2 de 3 HP x2 10-p010wm Screen Replacement: étape 4, image 3 de 3
    • Hold the screen with your thumb and push back on the plastic frame.
    • Slowly separate the plastic frame on all sides.
    • Be careful not to break the plastic frame.
  5. HP x2 10-p010wm Screen Replacement: étape 5, image 1 de 2 HP x2 10-p010wm Screen Replacement: étape 5, image 2 de 2
    • Remove the frame.
Nathan Ojala
Membre depuis le 10/30/19
317 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G3, Saloman Fall 2019 Membre de l'équipe UMass Dartmouth, Team S4-G3, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 9
Total : 396
