Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Pièces
Aucune pièce spécifiée.
  1. Remove the 2 Screw covers from the lower sides of the Bezel
    • Remove the 2 Screw covers from the lower sides of the Bezel
  2. Remove the 2 Screws using a PH#1
    • Remove the 2 Screws using a PH#1
  3. Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
    • Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
  4. Remove the 2 screws from the top of the frame, One on each side.
    • Remove the 2 screws from the top of the frame, One on each side.
  5. Remove the 4 screws holding the LCD to the frame. 2 on each side.
    • Remove the 4 screws holding the LCD to the frame. 2 on each side.
  6. Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
    • Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
Brent Norris
Membre depuis le 06/05/2017
457 Réputation
1 tutoriel rédigé
Équipe
Brents Computer Repair Membre de l'équipe Brents Computer Repair
Business
1 membre
1 tutoriel rédigé
Video guide How to disassemble HP Compaq G71 https://youtu.be/TsoP3EdbHz8
Viktorya - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 41
