Aller au contenu principal
HP-Pavillion 500-424 PC Series CPU Fan Replacement
Ce dont vous avez besoin
  1. HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: étape 1, image 1 de 2 HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: étape 1, image 2 de 2
    • Lay the tower down carefully on its right side, with the vents pointing up.
  2. HP-Pavillion 500-424 PC Series CPU Fan Replacement: étape 2, image 1 de 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: étape 2, image 2 de 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: étape 2, image 3 de 3
    • Use the flat head #6 screwdriver bit to unscrew the tower casing.
    • Very gently slide the case towards you.
    • Lift the casing up and gently place it off to the side.
  3. HP-Pavillion 500-424 PC Series CPU Fan Replacement: étape 3, image 1 de 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: étape 3, image 2 de 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: étape 3, image 3 de 3
    • Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up.
    • Remove each screw from the fan using the Phillips head screwdriver bit.
    • Place the screws in a cup, they are very small and can be lost easily.
    • Remove the old fan from the CPU.
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
2 autres ont terminé cette réparation.
Amanda Milby
Membre depuis le 09/13/18
177 Réputation
1 tutoriel rédigé
Équipe
Pasco Hernando, Team S5-G73, Prince Fall 2018 Membre de l'équipe Pasco Hernando, Team S5-G73, Prince Fall 2018
PHSC-PRINCE-F18S5G73
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 41
Total : 1,905
