Aller au contenu principal
HTC 7 Surround Camera Replacement
Ce dont vous avez besoin
  1. HTC 7 Surround Camera Replacement, Back Case: étape 1, image 1 de 2 HTC 7 Surround Camera Replacement, Back Case: étape 1, image 2 de 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC 7 Surround Camera Replacement: étape 2, image 1 de 3 HTC 7 Surround Camera Replacement: étape 2, image 2 de 3 HTC 7 Surround Camera Replacement: étape 2, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC 7 Surround Camera Replacement: étape 3, image 1 de 1
    • Separate the screen and back cover with the opening tool.
  4. HTC 7 Surround Camera Replacement, Rear Camera: étape 4, image 1 de 1
    • The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
    • The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
Michael Ronning
Membre depuis le 09/21/18
389 Réputation
4 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 195
