Introduction
Use this guide to replace or upgrade the battery in your Droid Incredible.
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
  • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
  • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Ajouter un commentaire
Remove the rear panel from the phone.
  • Remove the rear panel from the phone.
  • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
  • Lift the top of the battery up and remove the battery from the rear inner frame.
Andrew Optimus Goldberg
Membre depuis le 17/10/2009
383 897 Réputation
412 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
6 495 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,242
