Aller au contenu principal
HTC Droid Incredible Battery Replacement
  1. HTC Droid Incredible Battery Replacement, Battery: étape 1, image 1 de 3 HTC Droid Incredible Battery Replacement, Battery: étape 1, image 2 de 3 HTC Droid Incredible Battery Replacement, Battery: étape 1, image 3 de 3
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible Battery Replacement: étape 2, image 1 de 1
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible Battery Replacement: étape 3, image 1 de 3 HTC Droid Incredible Battery Replacement: étape 3, image 2 de 3 HTC Droid Incredible Battery Replacement: étape 3, image 3 de 3
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
502 858 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,583
