Aller au contenu principal
Introduction
This guide will walk you through the steps necessary to access the power button on your HTC Evo 4G for replacement. The four steps require no special skills. There are small parts that could get lost easily upon removal if not handled carefully.
  1. Using the tip of your finger, lift the battery from the end closest to the camera. Remove the battery from the rear inner frame.
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  2. Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
    • Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
  3. Use the plastic opening tool to gently pry the inner frame apart from the rest of the phone. Lift off the inner frame from the rest of the phone to remove it. Lift off the inner frame from the rest of the phone to remove it.
    • Use the plastic opening tool to gently pry the inner frame apart from the rest of the phone.
    • Lift off the inner frame from the rest of the phone to remove it.
  4. Carefully remove the power button located at the top of the phone Carefully remove the power button located at the top of the phone
    • Carefully remove the power button located at the top of the phone
Sage Jurado
Membre depuis le 13/03/2014
876 Réputation
4 tutoriels rédigés
Équipe
New Mexico State, Team 1-1, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-1, Easley Spring 2014
NMSU-EASLEY-S14S1G1
5 membres
4 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 449
