Aller au contenu principal
HTC EVO 4G Stand Replacement
Ce dont vous avez besoin
  1. HTC EVO 4G Stand Replacement, Battery: étape 1, image 1 de 2 HTC EVO 4G Stand Replacement, Battery: étape 1, image 2 de 2
    • Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
  2. HTC EVO 4G Stand Replacement: étape 2, image 1 de 2 HTC EVO 4G Stand Replacement: étape 2, image 2 de 2
    • Remove the battery from the phone by carefully lifting it out with your fingers.
  3. HTC EVO 4G Stand Replacement: étape 3, image 1 de 1
    • Set the battery aside for disposal. You are now ready to insert a new battery.
  4. HTC EVO 4G Stand Replacement, Stand: étape 4, image 1 de 1
    • you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
  5. HTC EVO 4G Stand Replacement: étape 5, image 1 de 3 HTC EVO 4G Stand Replacement: étape 5, image 2 de 3 HTC EVO 4G Stand Replacement: étape 5, image 3 de 3
    • Using the plastic opening tools again, gently pry the inner frame apart from the rest of the phone
    • Remove the inner frame from the rest of the phone by lifting it off
  6. HTC EVO 4G Stand Replacement: étape 6, image 1 de 1
    • Remove the five screws that are holding the stand in place.
  7. HTC EVO 4G Stand Replacement: étape 7, image 1 de 1
    • Remove the stand from the frame by lifting it out. Clear any debis causing it to be jammed, or replace with new stand.
Sage Jurado
Membre depuis le 03/13/14
1 128 Réputation
4 tutoriels rédigés
Équipe
New Mexico State, Team 1-1, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-1, Easley Spring 2014
NMSU-EASLEY-S14S1G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 153
