Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre HTC Evo 3D, utilisez notre manuel de réparation.
  1. HTC Evo 3D Teardown, HTC Evo 3D Teardown: étape 1, image 1 de 1
    • First things first, Remove the back cover, battery and SD card.
  2. HTC Evo 3D Teardown: étape 2, image 1 de 1
    • Remove the four T5 Torx screws.
    • Then remove the two Phillips screws.
    • *Very sorry for dark image*
  3. HTC Evo 3D Teardown: étape 3, image 1 de 1
    • Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
    • Begin from the bottom were the battery bay is, It is the easiest way.
    • Be careful of ribbons behind the plastic
  4. HTC Evo 3D Teardown: étape 4, image 1 de 3 HTC Evo 3D Teardown: étape 4, image 2 de 3 HTC Evo 3D Teardown: étape 4, image 3 de 3
    • Once separated begin to remove the LED board. Apply only light upward force and it will detach itself.
  5. HTC Evo 3D Teardown: étape 5, image 1 de 2 HTC Evo 3D Teardown: étape 5, image 2 de 2
    • Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
    • Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
    • Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
    • Tuck the ribbons in without bending or making tears in them.
  6. HTC Evo 3D Teardown: étape 6, image 1 de 1
    • Behind the main board is two more ribbon's.
    • Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
    • Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
    • As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
  7. HTC Evo 3D Teardown: étape 7, image 1 de 1
    • This concludes the (simple) teardown of the Evo 3D.
_Z_
Membre depuis le 03/18/12
9 710 Réputation
2 tutoriels rédigés
Équipe
Android Alliance Membre de l'équipe Android Alliance
Community
96 membres
757 tutoriels rédigés
1 commentaire de tutoriel
Thanks. This was very helpful.
dano706 - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 23
Total : 19,847
