Introduction
Replacing a broken or unresponsive HTC EXCA100 Keyboard
Ce dont vous avez besoin
Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
Pry loose the metal cover near the camera lens, circled in the picture.
After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
After loosening the case, remove it.
Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
