Introduction
This guide will help if you are having issues with the primary buttons sticking or not communicating with your device.
Pièces
Aucune pièce nécessaire.
Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
  • Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
Ajouter un commentaire
Fold the plastic flap open.
  • Fold the plastic flap open.
  • Pull on the red tab to slide the battery out.
  • Take out the battery.
  • Replace with new battery.
  • Use a T5 Torx screwdriver to remove the five screws anchoring the plastic flap to the phone.
  • One of the five screws may be hidden beneath a "Void" sticker to the right of the serial label.
  • Once the screws are removed from the plastic flap, the piece should easily come out.
  • After the screws are removed, fold circuit panel upwards, exposing the phone's primary buttons.
  • In order to remove the circuit board you must disconnect the labeled component.
  • Once the back side of the buttons are exposed, they will fall out either by punching them out from the front side, or by using tweezers to pull them out of the back.
Ryan Curtis
Membre depuis le 07/10/2014
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 8-3, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 8-3, Leahy Fall 2014
USFT-LEAHY-F14S8G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 362
