Introduction
This guide is one of the longer processes, second only to the Logic Board, or the screen. Have a reasonably long time set aside to complete this guide.
Ce dont vous avez besoin
Carefully pull the rear cover from the back of the phone.
Place a finger beneath the small lip on the left side of the battery.
Insert the flat end of a spudger between the midframe and the display.
Slide the spudger along the seam between the frame and the display.
Using the spudger for leverage, carefully pry the midframe away from the display assembly.
As it releases, pull the midframe away from the phone.
Disconnect the flash cable from its socket in the bottom of the motherboard.
Carefully pull the cable from its groove in the frame, working your way back to the camera.
2 autres ont terminé cette réparation.
