Introduction
This guide will help you get to the speaker, in case it needs to be replaced
Outils
Pièces
Aucune pièce spécifiée.
Carefully pull the rear cover from the back of the phone.
Place a finger beneath the small lip on the left side of the battery.
Insert the flat end of a spudger between the midframe and the display.
Slide the spudger along the seam between the frame and the display.
Using the spudger for leverage, carefully pry the midframe away from the display assembly.
As it releases, pull the midframe away from the phone.
With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
The speaker should be easily popped out of place with a small amount of force
