Aller au contenu principal
HTC Magic Speaker Replacement
Ce dont vous avez besoin
  1. HTC Magic Speaker Replacement, Speaker: étape 1, image 1 de 3 HTC Magic Speaker Replacement, Speaker: étape 1, image 2 de 3 HTC Magic Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Open the phone by removing it's backcover (battery door) and the battery.
    • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  2. HTC Magic Speaker Replacement: étape 2, image 1 de 1
    • Unscrew the six screws with a Torx T5 screwdriver.
  3. HTC Magic Speaker Replacement: étape 3, image 1 de 2 HTC Magic Speaker Replacement: étape 3, image 2 de 2
    • Remove the antenna (use the little gap at the top ).
    • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
    • The housing is held by plastic clips, so be careful since you don't want to break these.
    • Carefully lift the front housing from the back.
  4. HTC Magic Speaker Replacement: étape 5, image 1 de 2 HTC Magic Speaker Replacement: étape 5, image 2 de 2
    • The rear housing should look like the picture on the left. The speaker part is at the top.
    • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
LucasJV
Membre depuis le 05/18/10
735 Réputation
3 tutoriels rédigés
Équipe
Verheij.co Membre de l'équipe Verheij.co
Business
1 membre
5 tutoriels rédigés
Un commentaire
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 10,698
