Aller au contenu principal
Introduction
Use this guide to replace the headphone jack/micro USB board on your HTC One M9.
  1. Insert a microSD card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone above the volume buttons. Press to eject the tray. This may require a significant amount of force.
    • Insert a microSD card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone above the volume buttons.
    • Press to eject the tray.
    • This may require a significant amount of force.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray. The contacts should be inserted first and face to rear side.
    • It is normal, that the microSD card doesn't stay on it own inside the tray. It is also not completely trivial to place it correctly flat inside the tray.
  2. Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone. Press to eject the tray. This may require a significant amount of force.
    • Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
    • When reinserting the SIM card, ensure that its contacts are facing to the rear side. The tapered corner of the SIM card has to point to the outer bottom corner of the tray.
  3. Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case. Remove the two 4 mm T5 Torx screws on the top of the case. Remove the two 4 mm T5 Torx screws on the top of the case.
    • Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
    • Remove the two 4 mm T5 Torx screws on the top of the case.
  4. Work a plastic opening pick around the perimeter of the device to separate the rear case from the display assembly. The SIM card tray and Micro SD card tray must be removed before the back cover can be removed. Be careful around the power and volume buttons, as they are fairly delicate.
    • Work a plastic opening pick around the perimeter of the device to separate the rear case from the display assembly.
    • The SIM card tray and Micro SD card tray must be removed before the back cover can be removed.
    • Be careful around the power and volume buttons, as they are fairly delicate.
    • Be careful when separating the body from the display assembly, as the rear-facing camera may be stuck to the body with adhesive.
  5. Use a pair of tweezers to disconnect the blue and white antenna cables. Note that some models of this phone will have only one antenna cable at this location.
    • Use a pair of tweezers to disconnect the blue and white antenna cables. Note that some models of this phone will have only one antenna cable at this location.
  6. Ignorez les nouveaux gadgets.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    SKIPANDSAVE10
    Save Now
  7. Remove the two 1.5 mm Phillips screws securing the battery connector to the motherboard.
    • Remove the two 1.5 mm Phillips screws securing the battery connector to the motherboard.
    • Use a spudger to pry the battery connector from its socket, being careful to apply pressure only to the connector and not to the socket.
  8. Peel back the Kapton tape from the ZIF connector, then use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
    • Peel back the Kapton tape from the ZIF connector, then use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
  9. Peel back the Kapton tape from the ZIF connector, then use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
  10. With the tweezers, carefully lift up on the tape covering the electrical strip shown in the picture. Be careful with the tape as it can tear easily. You will have better luck if you pull back the orange Kapton tape rather than the silver electrical strip. Use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
    • With the tweezers, carefully lift up on the tape covering the electrical strip shown in the picture.
    • Be careful with the tape as it can tear easily. You will have better luck if you pull back the orange Kapton tape rather than the silver electrical strip.
    • Use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
  11. Peel back the Kapton tape from the remaining three ZIF connectors, then use your fingernail or a spudger to lift the hinged retainer clips on the ZIF connectors and slide the cables out from each. The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath. The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
    • Peel back the Kapton tape from the remaining three ZIF connectors, then use your fingernail or a spudger to lift the hinged retainer clips on the ZIF connectors and slide the cables out from each.
    • The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
  12. Remove the dual LED flash cover. This is held on with a small amount of adhesive. Be careful here: the flash cover may be glued to the antenna cable(s) below. Apply a small amount of heat here to soften the adhesive before removal. Use a pair of tweezers to disconnect the two antenna cables near the camera. Note that some models of this phone will have only one antenna cable at this location. Use a pair of tweezers to disconnect the antenna cable near the bottom of the phone.
    • Remove the dual LED flash cover. This is held on with a small amount of adhesive. Be careful here: the flash cover may be glued to the antenna cable(s) below. Apply a small amount of heat here to soften the adhesive before removal.
    • Use a pair of tweezers to disconnect the two antenna cables near the camera. Note that some models of this phone will have only one antenna cable at this location.
    • Use a pair of tweezers to disconnect the antenna cable near the bottom of the phone.
  13. Remove the three 4mm T5 Torx screws securing the motherboard.
    • Remove the three 4mm T5 Torx screws securing the motherboard.
  14. Use a pair of tweezers to gently lift the vibrator out of its crevace. It is held in only with friction, no adhesive or screws. Be careful when lifting to avoid damaging the wires connecting it to the motherboard. Use a plastic opening tool or a spudger to gently pry the motherboard out of the case. lift first from the top (near the camera).
    • Use a pair of tweezers to gently lift the vibrator out of its crevace. It is held in only with friction, no adhesive or screws. Be careful when lifting to avoid damaging the wires connecting it to the motherboard.
    • Use a plastic opening tool or a spudger to gently pry the motherboard out of the case. lift first from the top (near the camera).
    • The motherboard is secured with adhesive at the bottom (on the speaker assembly) so you may need to use an iOpener or heat gun to loosen the adhesive. Refer to the iOpener guide for info on this.
  15. Remove the 3 mm T5 screw that holds the front speaker in place. This screw was missing due to mishandling in an earlier deconstruction.
    • Remove the 3 mm T5 screw that holds the front speaker in place.
    • This screw was missing due to mishandling in an earlier deconstruction.
    • Gently remove the speaker from the device.
  16. Use a pair of tweezers to remove the headphone jack/micro USB board. Use a pair of tweezers to remove the headphone jack/micro USB board.
    • Use a pair of tweezers to remove the headphone jack/micro USB board.
8 autre(s) ont terminé cette réparation.
Michael Chan
Membre depuis le 14/04/2015
2 061 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-16, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-16, Maness Spring 2015
CPSU-MANESS-S15S6G16
4 membres
13 tutoriels rédigés
Hi,
Make sure to check the headphone board too see if the gps connection in your phone has 1 or 2 cable ports.(Blue jumper wires) Mine has 1 so I got a sim card error. Waiting for usb board with one cable to fix
nateraymond008 - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 42
Total : 10,772
