Aller au contenu principal
HTC One Max Back Case Replacement
Ce dont vous avez besoin
  1. HTC One Max Back Case Replacement, Back Case: étape 1, image 1 de 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Back Case Replacement: étape 2, image 1 de 2 HTC One Max Back Case Replacement: étape 2, image 2 de 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Back Case Replacement: étape 3, image 1 de 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    The orange circle in line with the 4 other red circles down the RH side (as shown) in the photo should be red also, as this shows a screw, not the cable (which is by the volume buttons).
    Huey Smith - Réponse
    Hey Huey,
    Nice catch! This has now been fixed.
    Geoff Wacker -
  4. HTC One Max Back Case Replacement: étape 4, image 1 de 2 HTC One Max Back Case Replacement: étape 4, image 2 de 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
4 autres ont terminé cette réparation.
Andrew Keller
Membre depuis le 09/23/14
1 131 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 11-3, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 membres
7 tutoriels rédigés
5 commentaires
any idea where i can purchase that back case?
omair - Réponse
The "Tools" section of the guide lists a Y0 screwdriver as required but in the steps it says Y1. Now I have a Y0 screwdriver i can't do anything with and i have to order a Y1. Hopefully that is accurate.
khaydin - Réponse
Soooo... unless your HTC One MAX is completely different from the Sprint one i'm trying to replace the back on, both the Y0 and Y1 screw drivers are WRONG for this phone. They are both a bit too big to work on the screws. Now I've bought TWO screw drivers from you guys that were incorrect. Guess i'm gonna need to go out and buy a tri-wing screw driver set.
khaydin -
You need a #Y00 which is smaller then a #Y0 and #Y1 .
Leonturner21 -
The site tells you to use a #Y00 and it does work for any HTC One Max
Leonturner21 -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 18
Total : 3,750
