Introduction
In this guide you will learn how to replace the motherboard in the HTC One Max.
Ce dont vous avez besoin
Lift back cover while pressing highlighted release switch towards the center of the phone.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
6 autres ont terminé cette réparation.
