Introduction
This guide is for replacing the top and bottom speakers, which HTC calls the dual speakers. Make sure you have a good area to work and plenty of time.
Ce dont vous avez besoin
Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
Set the cardholders aside.
Use a metal spudger to pry up the left edge of the upper grey front plate.
Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
Peel off the long yellow pieces of tape on the right and left side of the copper plate.
Use the flat end of the plastic spudger to pry the lower speaker out.
Holding the phone, pull the speaker to the right pulling the connector out of the board.
Peel off the yellow tape covering the power button connector using the pointed end of the spudger.
Pop up the white tab on the ribbon cable connector for the power button located on the top right of the phone.
Carefully pull out the ribbon cable.
2 autres ont terminé cette réparation.
