Introduction
Follow the instructions in this repair guide to successfully remove the rear case of your HTC One Mini, locate the phone's battery, and remove it so that a new one may replace it.
Ce dont vous avez besoin
Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
Remove the lower speaker cover.
Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
Using the spudger, use force to detach and remove the speaker.
11 autres ont terminé cette réparation.
6 commentaires
Please tell me,can i use battery from htc one mini 2 in htc one mini? I just want increase the battery capacity from 1800 to 2100.thanks for the answer
I completed the steps as described and have an issue with my display now. I tried to start the device before pressing it in the back cover to check whether it works or not. It seems to work, but the display don't. Which cable is that of the display and / or what could have gone wrong? Thx!
I changed the battery, but now, the sound doesn't works. The microphone and the diffuser do not work. What can I do ?
