Introduction
If your rear camera isn't working anymore, replace it using this guide.
Ce dont vous avez besoin
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Handling it by the tag, place the heated iOpener across the bottom casing.
Using the pointed end of a spudger, lift the battery cable and release the connector.
Outil utilisé dans cette étape :Tweezers$4.99
Similar to step 18, remove the polyimide tape with tweezers.
