Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HTC One X Button Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. HTC One X Button Replacement, Remove SIM card slot: étape 1, image 1 de 1
    • Insert a safety pin, or other small object in the small opening next to the Sim card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
    Demander à FixBot
    Ajouter un commentaire
  2. HTC One X Button Replacement, Remove front panel: étape 2, image 1 de 2 HTC One X Button Replacement, Remove front panel: étape 2, image 2 de 2
    • Using a plastic opening tool, carefully separate the display screen from the rear panel.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage.
    • Set aside the rear panel.
    Demander à FixBot
  3. HTC One X Button Replacement, Remove the top plastic panel: étape 3, image 1 de 2 HTC One X Button Replacement, Remove the top plastic panel: étape 3, image 2 de 2
    • Remove the five screws at the top of the panel using a Phillips head screwdriver.
    • Two 2.05mm Philips head screws
    • Three 2.44mm Philips head screws
    • Also remove the screws with the warranty stickers.
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
    • Once you have disassembled your device, your warranty will no longer be valid.
    Demander à FixBot
  4. HTC One X Button Replacement, Remove antenna and disconnect the PCB board: étape 4, image 1 de 2 HTC One X Button Replacement, Remove antenna and disconnect the PCB board: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the two screws at the bottom right corner of the front panel using a Phillips head screwdriver, as shown in the image.
    • Two 3.35mm Philips head screws
    • Use tweezers to disconnect the antenna from the logic board to the PCB board.
    • Remove the tape connected to the motherboard.
    Demander à FixBot
  5. HTC One X Button Replacement, Disconnect the battery and remove PCB board: étape 5, image 1 de 3 HTC One X Button Replacement, Disconnect the battery and remove PCB board: étape 5, image 2 de 3 HTC One X Button Replacement, Disconnect the battery and remove PCB board: étape 5, image 3 de 3
    • Remove the tape holding the battery in place.
    • Gently lift the battery from the bottom using a plastic opening tool.
    • You may have to apply heat to melt the glue holding the battery in place.
    • Do not completely remove the battery yet
    • You can now disconnect the flex cable holding the PCB board place. Gently open the gates using tweezers or a plastic opening tool and use tweezers to slide the flex cable out.
    • Now that it's separated, remove and set aside the PCB board.
    Demander à FixBot
  6. HTC One X Button Replacement, Disconnect flex cables: étape 6, image 1 de 3 HTC One X Button Replacement, Disconnect flex cables: étape 6, image 2 de 3 HTC One X Button Replacement, Disconnect flex cables: étape 6, image 3 de 3
    • Place the battery back into its original position once the PCB board has been removed
    • Use tweezers to disconnect the power button flex cables.
    • Disconnect the volume flex cable by opening the gate and then sliding the cable out using tweezers.
    • Disconnect the touchscreen flex cable
    • If repairing hard buttons, skip step 7.
    Demander à FixBot
  7. HTC One X Button Replacement, Remove logic board: étape 7, image 1 de 1
    • Disconnect the remaining two flex cables in a similar manner before completely removing the logic board.
    • You may now remove the board safely
    Demander à FixBot
  8. HTC One X Button Replacement, Ensure flex cables and buttons are connected: étape 8, image 1 de 2 HTC One X Button Replacement, Ensure flex cables and buttons are connected: étape 8, image 2 de 2
    • Ensure that the power button flex cable from Step 6 is connected securely with its base.
    • Ensure that the volume flex cable from Step 6 is connected securely with its base.
    • If necessary you may need to replace these flex cables completely.
    • Follow these steps in reverse and specifically check the power and volume buttons as they're placed into the phone.
    Demander à FixBot
4 autres ont terminé cette réparation.
Nyles Peterson
Membre depuis le 09/22/14
1 897 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 4-3, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
3 membres
12 tutoriels rédigés
1 commentaire de tutoriel
Mera phone htc one x hi jo chalu nahi ho raha hi ab mi kya karu mene phone ko pura khola tha
Abhishek tripathi - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 46
Total : 2,994
