Introduction
HTC One X is also known as S720E.
How to disassemble the phone and change the LCD Display & Touchscreen / Digitizer (the complete spare part).
Please SUBSCRIBE to my channel ツ
Vidéo d'introduction
Switch-off the phone (if you can).
  • Switch-off the phone (if you can).
  • Remove the SIM tray.
  • The back cover is sticked to the phone with adhesive tape. Is good to use some hot air to do removing of the back cover easier.
Ajouter un commentaire
Start opening from the bottom side.
  • Start opening from the bottom side.
  • For separating the back cover, use only plastic tools.
Be careful around the bottom corners and edges, that you don't put your guitar pick in to deep and break a pin off the logic board.
Josh Ginsberg - Réponse
There are 3 types of screens! Sony, Sharp and AUO (or something). Look at the color of the flexwire before you order or install. I made the mistake and burned the backlight coil.
35i - Réponse
hi. which flexwire to whach?
dkdanniell -
  • The mother board is held by 6x Philips screws.
  • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
  • Use a plastic tool to unstick the battery.
  • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
  • Now you can separate the Dock flex cable.
  • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
  • Disconnect the Power On button flex cable at the upper side of the phone
  • Now the mainboard and the battery are free.
  • Disconnect the battery from the mainboard.
  • At the beginning you can use a cutter to make a room for the plastic tool.
  • During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy.
  • The original adhesive tape is left on the frame, but I prefer to put new. I put it onto the original.
  • Gently assemble the screen to the frame.
13 autre(s) ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
156 577 Réputation
304 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
277 membres
748 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 86
Total : 35,713
