Aller au contenu principal
HTC Ozone Keyboard Replacement
Ce dont vous avez besoin
  1. HTC Ozone Keyboard Replacement, Rear Battery Cover: étape 1, image 1 de 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Keyboard Replacement: étape 2, image 1 de 2 HTC Ozone Keyboard Replacement: étape 2, image 2 de 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Keyboard Replacement, Battery: étape 3, image 1 de 3 HTC Ozone Keyboard Replacement, Battery: étape 3, image 2 de 3 HTC Ozone Keyboard Replacement, Battery: étape 3, image 3 de 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Keyboard Replacement, Frame: étape 4, image 1 de 3 HTC Ozone Keyboard Replacement, Frame: étape 4, image 2 de 3 HTC Ozone Keyboard Replacement, Frame: étape 4, image 3 de 3
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Keyboard Replacement: étape 5, image 1 de 3 HTC Ozone Keyboard Replacement: étape 5, image 2 de 3 HTC Ozone Keyboard Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Keyboard Replacement, Motherboard: étape 6, image 1 de 2 HTC Ozone Keyboard Replacement, Motherboard: étape 6, image 2 de 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Keyboard Replacement: étape 7, image 1 de 2 HTC Ozone Keyboard Replacement: étape 7, image 2 de 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Keyboard Replacement: étape 8, image 1 de 3 HTC Ozone Keyboard Replacement: étape 8, image 2 de 3 HTC Ozone Keyboard Replacement: étape 8, image 3 de 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
  9. HTC Ozone Keyboard Replacement, LCD Display: étape 9, image 1 de 2 HTC Ozone Keyboard Replacement, LCD Display: étape 9, image 2 de 2
    • Remove the gray tape securing the ribbon cable.
  10. HTC Ozone Keyboard Replacement: étape 10, image 1 de 1
    • Remove the yellow tape securing the connector lock.
  11. HTC Ozone Keyboard Replacement: étape 11, image 1 de 2 HTC Ozone Keyboard Replacement: étape 11, image 2 de 2
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  12. HTC Ozone Keyboard Replacement: étape 12, image 1 de 1
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  13. HTC Ozone Keyboard Replacement: étape 13, image 1 de 1
    • Lift the Motherboard away from the LCD display.
  14. HTC Ozone Keyboard Replacement, Keyboard: étape 14, image 1 de 2 HTC Ozone Keyboard Replacement, Keyboard: étape 14, image 2 de 2
    • Lift off main keyboard from front plastic case using plastic opening tool.
  15. HTC Ozone Keyboard Replacement: étape 15, image 1 de 2 HTC Ozone Keyboard Replacement: étape 15, image 2 de 2
    • Remove four Phillips #00 screws securing function keys.
  16. HTC Ozone Keyboard Replacement: étape 16, image 1 de 2 HTC Ozone Keyboard Replacement: étape 16, image 2 de 2
    • Pop keys out by pushing keys from back of the phone.
Marco Jokada
Membre depuis le 04/28/11
247 Réputation
6 tutoriels rédigés
Équipe
CSU Los Angeles, Team 1-2, Nelson Spring 2011 Membre de l'équipe CSU Los Angeles, Team 1-2, Nelson Spring 2011
CSULA-NELSON-S11S1G2
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,769
