Aller au contenu principal
HTC Surround SD Card Replacement
Ce dont vous avez besoin
  1. HTC Surround SD Card Replacement, Back Case: étape 1, image 1 de 2 HTC Surround SD Card Replacement, Back Case: étape 1, image 2 de 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround SD Card Replacement: étape 2, image 1 de 3 HTC Surround SD Card Replacement: étape 2, image 2 de 3 HTC Surround SD Card Replacement: étape 2, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround SD Card Replacement: étape 3, image 1 de 1
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround SD Card Replacement, SD Card: étape 4, image 1 de 3 HTC Surround SD Card Replacement, SD Card: étape 4, image 2 de 3 HTC Surround SD Card Replacement, SD Card: étape 4, image 3 de 3
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround SD Card Replacement: étape 5, image 1 de 2 HTC Surround SD Card Replacement: étape 5, image 2 de 2
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
Michael Ronning
Membre depuis le 09/21/18
389 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 244
