Introduction
Use this guide to replace a broken or damaged camera.
Ce dont vous avez besoin
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Remove the two Phillips screws securing rear inner frame to device.
Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
Use a pair of tweezers to pull the capacitive button cable out of its socket.
Use a finger nail to get in between the tape and the phone, then pull the tape off gently.
