Aller au contenu principal
Introduction
Use this guide to remove the microSD prior to taking apart the rest of the device.
Pièces
Aucune pièce spécifiée.
  1. Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. Lift and remove the rear panel.
    • Lift and remove the rear panel.
  3. Batteries pour ordinateurs portables
    Une réparation facile pour un gain en puissance max.
    Acheter maintenant
    Acheter maintenant
  4. Using the plastic opening tool, lift up the battery from the bottom near the kickstand. Remove the battery from the inner frame.
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  5. Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing. Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  6. Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
Vanessa
Membre depuis le 18/01/2013
60 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 19-45, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 membres
12 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,192
