Aller au contenu principal
HTC Touch Camera Lens Replacement
Ce dont vous avez besoin
  1. HTC Touch Camera Lens Replacement, Camera Lens: étape 1, image 1 de 1
    • Remove the back panel by sliding it up.
  2. HTC Touch Camera Lens Replacement: étape 2, image 1 de 1
    • Remove the battery.
  3. HTC Touch Camera Lens Replacement: étape 3, image 1 de 1
    • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
  4. HTC Touch Camera Lens Replacement: étape 4, image 1 de 2 HTC Touch Camera Lens Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to remove the front panel from the phone.
    • Unplug the front button cable from the inside of the phone.
  5. HTC Touch Camera Lens Replacement: étape 5, image 1 de 1
    • Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
  6. HTC Touch Camera Lens Replacement: étape 6, image 1 de 2 HTC Touch Camera Lens Replacement: étape 6, image 2 de 2
    • Seperate the motherboard from the black plastic casing.
    • Unplug the black and red wire from the motherboard.
    • Unplug the black and red wire from the black plastic casing.
  7. HTC Touch Camera Lens Replacement: étape 7, image 1 de 1
    • Lift the black lever next to the orange ribbon cable to remove the LCD Screen.
  8. HTC Touch Camera Lens Replacement: étape 8, image 1 de 1
    • Remove the camera lens from the motherboard using the plastic opening tool.
Sehyun
Membre depuis le 03/31/11
57 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-12, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,645
