Aller au contenu principal
HTC Touch Pro 2 Housing Replacement
Ce dont vous avez besoin
  1. HTC Touch Pro 2 Housing Replacement, Battery: étape 1, image 1 de 3 HTC Touch Pro 2 Housing Replacement, Battery: étape 1, image 2 de 3 HTC Touch Pro 2 Housing Replacement, Battery: étape 1, image 3 de 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Housing Replacement: étape 2, image 1 de 2 HTC Touch Pro 2 Housing Replacement: étape 2, image 2 de 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners
  3. HTC Touch Pro 2 Housing Replacement, Housing: étape 3, image 1 de 2 HTC Touch Pro 2 Housing Replacement, Housing: étape 3, image 2 de 2
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • There is a ribbon attached on the back of this part that requires caution to remove.
  4. HTC Touch Pro 2 Housing Replacement: étape 4, image 1 de 3 HTC Touch Pro 2 Housing Replacement: étape 4, image 2 de 3 HTC Touch Pro 2 Housing Replacement: étape 4, image 3 de 3
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
2 autres ont terminé cette réparation.
Melinda Phan
Membre depuis le 04/17/11
438 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 9-64, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 9
Total : 3,886
