Introduction
Replacement of the HTC Touch Pro's motherboard.
  1. First, gently press on the back plate and push down toward the camera.
    • First, gently press on the back plate and push down toward the camera.
  2. Use your finger to lift up the edge of the battery.
    • Use your finger to lift up the edge of the battery.
    • Remove the 4 screws using the T6 screw driver.
    • Lift the plastic cover near the memory card slot.
    • Remove the two Phillips #00 screws from the backside of the screen.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
Zhaowei Zhang
Membre depuis le 28/04/2011
112 Réputation
4 tutoriels rédigés
Équipe
CSU Los Angeles, Team 1-6, Nelson Spring 2011 Membre de l'équipe CSU Los Angeles, Team 1-6, Nelson Spring 2011
CSULA-NELSON-S11S1G6
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,920
