Introduction
Suivez ce tutoriel pour retirer ou remplacer le panneau frontal de la manette HTC Vive. Veillez à ne déchirer ni les nappes ni leurs connecteurs lors du retrait du panneau frontal.
Ce dont vous avez besoin
Retournez la manette Vive de façon à ce que la coque inférieure est tournée vers le haut.
Utilisez un tournevis Torx T5 pour dévisser les trois vis noires de 21 mm de la coque circulaire inférieure.
Séparez la coque inférieure de la coque supérieure tout autour des bords à l'aide d'une spatule en nylon.
Retirez la coque supérieure en la soulevant avec votre main.
My top saucer was REALLY stubborn. Don’t force it with your hand, use the spudger to separate it at the seam. Try not to poke your spudger in too deep, there are internals just inside the seam.
The second time around, I learned why it was so stubborn. The picture suggests that you should start at the base of the saucer and work your way around, but that’s backwards.
Start separating with your spudger at the distal side of the saucer and work your way toward the handle. Then for the last part, pull the piece up and away, like peeling a banana. See the second picture for the bottom half of the saucer, below. Do the same on the top.
Utilisez un tournevis cruciforme #00 pour dévisser les trois vis argentées de 12,8 mm du panneau de capteurs supérieur.
It’s Phillips 0, not 00.
You do not need to remove these screws to remove the bottom saucer. They provide stability to the two halves of the donut.
I had the same experience. Putting the screws back in made the bottom shell easier to remove.
I concur, you don’t need to remove these screws to take the bottom shell off.
I found mine had ph#000 screws size, not ph#00.
please do not remove the Phillips-head screws it is not necessary to remove them.
Retirez soigneusement la coque circulaire inférieure avec votre main.
From what I can tell, there are two clicks on each side? one is quite easy, then the other one seems to require considerable force pushing down and on the side, I had to do it one side at a time and found two YouTube videos performing this step to use as reference. I have the vive pro wands and not the originals, so this may explain the difference. This felt very wrong to me.
Utilisez un tournevis Torx T5 pour dévisser les deux vis noires de 5,2 mm sur la coque arrière grise.
Retournez la manette Vive de façon à ce que l'anneau circulaire exposé est face en haut.
Utilisez un tournevis Torx T5 pour retirer les trois vis noires de 5,2 mm.
Leave the middle screw where it is (the one being unscrewed in the picture). That screw holds the two halves of the photodiode assembly together, not the case.
five screws… two at bottom
I concur with trevosklar, don’t need to remove center screw to remove front panel (pad cover).
Déconnectez la nappe supérieure en la tirant soigneusement avec deux doigts vers le haut et en l'éloignant de la carte mère.
You do not have to remove the ribbon cables from the plugs…you can carefully work the battery holder around them and remove it…being very gentle. And the black part of the handle will stay attached to the cables and be in the way. But removing the cables does make it easier to access the area for the battery, just not completely necessary.
Déconnectez la nappe centrale en la tirant délicatement avec deux doigts vers le haut et en l'éloignant de la carte mère.
Utilisez la spatule en nylon pour soulever la languette blanche de 90°.
Déconnectez la nappe inférieure en la tirant vers le bas avec deux doigts.
Hallo what is the name of this conector because i Broker it
Yeah I did as instructed only to realize after that my gen 1 vive controller does not do that, and i desoldered the power button ribbon. That cable, does NOT detach on my model. destroyed.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
11 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Where can I buy new t5 21 mm screws? Mine are getting stripped out!
jeremyvanwoerden - Réponse
Where can you get replacement batteries?
Mike Justice - Réponse
The middle bottom screw may have some form of warranty sticker on it if you have a Vive Pro wand (which is purple). Mine had this. Easy enough to remove and get on with it.
sodiboo - Réponse
