Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HTC Vive Pro Headphones Replacement
Ce dont vous avez besoin
  1. HTC Vive Pro Headphones Replacement, Remove the head strap padding: étape 1, image 1 de 3 HTC Vive Pro Headphones Replacement, Remove the head strap padding: étape 1, image 2 de 3 HTC Vive Pro Headphones Replacement, Remove the head strap padding: étape 1, image 3 de 3
    • Peel off the thin piece of padding covering the headphone screw for each headphone you're replacing.
  2. HTC Vive Pro Headphones Replacement, Unscrew the headphones: étape 2, image 1 de 2 HTC Vive Pro Headphones Replacement, Unscrew the headphones: étape 2, image 2 de 2
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing each headphone you are replacing.
  3. HTC Vive Pro Headphones Replacement, Remove the headphones: étape 3, image 1 de 3 HTC Vive Pro Headphones Replacement, Remove the headphones: étape 3, image 2 de 3 HTC Vive Pro Headphones Replacement, Remove the headphones: étape 3, image 3 de 3
    • Remove the headphones.
  4. HTC Vive Pro Headphones Replacement, Remove the headphone pad: étape 4, image 1 de 2 HTC Vive Pro Headphones Replacement, Remove the headphone pad: étape 4, image 2 de 2
    • Insert an opening pick under the headphone pad and pry up to unclip it from the headphone.
  5. HTC Vive Pro Headphones Replacement: étape 5, image 1 de 2 HTC Vive Pro Headphones Replacement: étape 5, image 2 de 2
    • Pull the headphone pad straight off the headphone to remove it.
  6. HTC Vive Pro Headphones Replacement: étape 6, image 1 de 1
    • You're now left with the headphone for replacement.
Sam Omiotek
Membre depuis le 02/25/19
97 206 Réputation
290 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 29
Total : 2,648
