Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HTC Vive XR Elite Proximity Sensor Replacement
Ce dont vous avez besoin
  1. HTC Vive XR Elite Proximity Sensor Replacement, Prepare your Vive XR Elite for disassembly: étape 1, image 1 de 1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
    Demander à FixBot
    Ajouter un commentaire
  2. HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the USB-C power cable: étape 2, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the USB-C power cable: étape 2, image 2 de 2
    • Disconnect the USB-C power cable.
    Demander à FixBot
  3. HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the battery cradle: étape 3, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the battery cradle: étape 3, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the battery cradle: étape 3, image 3 de 3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
    Demander à FixBot
  4. HTC Vive XR Elite Proximity Sensor Replacement: étape 4, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 4, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 4, image 3 de 3
    • Repeat the previous step for the left temple slot.
    Demander à FixBot
  5. HTC Vive XR Elite Proximity Sensor Replacement, Separate the headset and battery cradle: étape 5, image 1 de 1
    • Separate the headset and battery cradle.
    Demander à FixBot
  6. HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cushion: étape 6, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cushion: étape 6, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cushion: étape 6, image 3 de 3
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
    Demander à FixBot
  7. HTC Vive XR Elite Proximity Sensor Replacement, Remove the screw covers: étape 7, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the screw covers: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to remove the six screw covers from the right temple.
    Demander à FixBot
  8. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the right temple: étape 8, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the right temple: étape 8, image 2 de 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
    Demander à FixBot
  9. HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: étape 9, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: étape 9, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: étape 9, image 3 de 3
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
    Demander à FixBot
  10. HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer temple: étape 10, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer temple: étape 10, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer temple: étape 10, image 3 de 3
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
    Demander à FixBot
  11. HTC Vive XR Elite Proximity Sensor Replacement: étape 11, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 11, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 11, image 3 de 3
    • Slide the top of the outer temple out of its slot in the hinge.
    Demander à FixBot
  12. HTC Vive XR Elite Proximity Sensor Replacement: étape 12, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement: étape 12, image 2 de 2
    Tesa 61395 Tape
    $10.95
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
    Demander à FixBot
  13. HTC Vive XR Elite Proximity Sensor Replacement: étape 13, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 13, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 13, image 3 de 3
    • Thread the outer temple off of the USB‑C cable and remove it.
    Demander à FixBot
  14. HTC Vive XR Elite Proximity Sensor Replacement: étape 14, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement: étape 14, image 2 de 2
    • Pull the inner temple out of its slot in the hinge and remove it.
    Demander à FixBot
  15. HTC Vive XR Elite Proximity Sensor Replacement, Peel the hinge tape: étape 15, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Peel the hinge tape: étape 15, image 2 de 2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
    Demander à FixBot
  16. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the inner hinge cover: étape 16, image 1 de 1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
    Demander à FixBot
  17. HTC Vive XR Elite Proximity Sensor Replacement, Remove the inner hinge cover: étape 17, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the inner hinge cover: étape 17, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the inner hinge cover: étape 17, image 3 de 3
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
    Demander à FixBot
  18. HTC Vive XR Elite Proximity Sensor Replacement, Remove the screw covers: étape 18, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the screw covers: étape 18, image 2 de 2
    • Use tweezers to remove the six screw covers from the left temple.
    Demander à FixBot
  19. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the left temple: étape 19, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the left temple: étape 19, image 2 de 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
    Demander à FixBot
  20. HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: étape 20, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: étape 20, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the outer hinge cover: étape 20, image 3 de 3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
    Demander à FixBot
  21. HTC Vive XR Elite Proximity Sensor Replacement, Remove the left temple: étape 21, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the left temple: étape 21, image 2 de 2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
    Demander à FixBot
  22. HTC Vive XR Elite Proximity Sensor Replacement: étape 22, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement: étape 22, image 2 de 2
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
    Demander à FixBot
  23. HTC Vive XR Elite Proximity Sensor Replacement: étape 23, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement: étape 23, image 2 de 2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
    Demander à FixBot
  24. HTC Vive XR Elite Proximity Sensor Replacement: étape 24, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement: étape 24, image 2 de 2
    Tesa 61395 Tape
    $10.95
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
    Demander à FixBot
  25. HTC Vive XR Elite Proximity Sensor Replacement, Peel the hinge tape: étape 25, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Peel the hinge tape: étape 25, image 2 de 2
    Demander à FixBot
  26. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the inner hinge cover: étape 26, image 1 de 1
    • One 3.5 mm‑long screw
    Demander à FixBot
  27. HTC Vive XR Elite Proximity Sensor Replacement, Reposition the inner hinge cover: étape 27, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the inner hinge cover: étape 27, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the inner hinge cover: étape 27, image 3 de 3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
    Demander à FixBot
  28. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the face plate: étape 28, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the face plate: étape 28, image 2 de 2
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
    Demander à FixBot
  29. HTC Vive XR Elite Proximity Sensor Replacement, Unclip the face cover: étape 29, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Unclip the face cover: étape 29, image 2 de 2
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
    Demander à FixBot
  30. HTC Vive XR Elite Proximity Sensor Replacement: étape 30, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement: étape 30, image 2 de 2
    • Repeat the prying process for the middle and bottom left portions of the face cover.
    Demander à FixBot
  31. HTC Vive XR Elite Proximity Sensor Replacement, Reposition the face cover: étape 31, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the face cover: étape 31, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the face cover: étape 31, image 3 de 3
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
    Demander à FixBot
  32. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the proximity sensor: étape 32, image 1 de 1
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
    Demander à FixBot
  33. HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cover: étape 33, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the face cover: étape 33, image 2 de 2
    • Remove the face cover.
    Demander à FixBot
  34. HTC Vive XR Elite Proximity Sensor Replacement, Reposition the lens assembly: étape 34, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the lens assembly: étape 34, image 2 de 2
    • Pull the two lenses outward so they're as far apart as possible.
    Demander à FixBot
  35. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the lens assembly: étape 35, image 1 de 1
    • Use a T5 Torx screwdriver to remove the four screws securing the lens assembly:
    • Three 4.9 mm‑long screws
    • One 3.3 mm‑long screw
    Demander à FixBot
  36. HTC Vive XR Elite Proximity Sensor Replacement, Remove the brackets: étape 36, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the brackets: étape 36, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Remove the brackets: étape 36, image 3 de 3
    • The screw brackets are secured with clips and adhesive.
    • Use tweezers to pull the left screw bracket of its post in the frame.
    • This may require some force. Be careful not to scratch any surrounding components.
    • Repeat this process for the right bracket.
    • During reassembly, use tweezers to align the brackets on their posts. Press down with the flat end of a spudger to engage and re-adhere the clips.
    Demander à FixBot
  37. HTC Vive XR Elite Proximity Sensor Replacement, Reposition the lens assembly: étape 37, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Reposition the lens assembly: étape 37, image 2 de 2
    • Lift the bottom of the lens assembly up to separate the bottom rails from their slots in the frame.
    Demander à FixBot
  38. HTC Vive XR Elite Proximity Sensor Replacement: étape 38, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 38, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 38, image 3 de 3
    • Pull the lens assembly upwards to separate the top rails from their slots in the frame.
    • Rotate the lens assembly towards the top of the frame so it sits upright with its cable connectors exposed.
    Demander à FixBot
  39. HTC Vive XR Elite Proximity Sensor Replacement, Unfasten the lens assembly cables: étape 39, image 1 de 1
    • Use a T5 Torx screwdriver to remove the four 3.4 mm‑long screws securing the lens assembly cables.
    Demander à FixBot
  40. HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the lens assembly cables: étape 40, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the lens assembly cables: étape 40, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the lens assembly cables: étape 40, image 3 de 3
    • Use the flat end of a spudger to pry up and disconnect the lens assembly cable connector.
    • Repeat this procedure for the other connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Demander à FixBot
  41. HTC Vive XR Elite Proximity Sensor Replacement, Remove the lens assembly: étape 41, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Remove the lens assembly: étape 41, image 2 de 2
    • Lift up and remove the lens assembly.
    Demander à FixBot
  42. HTC Vive XR Elite Proximity Sensor Replacement, Reassembly information: étape 42, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Reassembly information: étape 42, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Reassembly information: étape 42, image 3 de 3
    • The next four steps demonstrate how to secure the lens assembly to the frame during reassembly.
    • In order for the lens assembly to rest in the frame properly, it needs to align with a peg in the IPD (interpupillary distance) slider.
    • Before reinstalling the lens assembly, push the IPD slider to its right-most position.
    Demander à FixBot
  43. HTC Vive XR Elite Proximity Sensor Replacement: étape 43, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 43, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 43, image 3 de 3
    • Pull the lens assembly outward until its plastic clips sit close to the end of the top rails.
    • You may need to push and pull the top rail so it sits evenly across the plastic clips.
    Demander à FixBot
  44. HTC Vive XR Elite Proximity Sensor Replacement: étape 44, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 44, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 44, image 3 de 3
    • Push the bottom rails inwards as far as they will go.
    Demander à FixBot
  45. HTC Vive XR Elite Proximity Sensor Replacement: étape 45, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 45, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement: étape 45, image 3 de 3
    • To secure the lens assembly into the frame:
    • Slide the top left rail into its slot.
    • Align the other rails.
    • Press the lens assembly into place, making sure to realign the center peg.
    Demander à FixBot
  46. HTC Vive XR Elite Proximity Sensor Replacement, Peel the tape: étape 46, image 1 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Peel the tape: étape 46, image 2 de 3 HTC Vive XR Elite Proximity Sensor Replacement, Peel the tape: étape 46, image 3 de 3
    Demander à FixBot
  47. HTC Vive XR Elite Proximity Sensor Replacement: étape 47, image 1 de 1
    • Peel off the yellow tape covering the proximity sensor connector.
    Demander à FixBot
  48. HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the proximity sensor: étape 48, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement, Disconnect the proximity sensor: étape 48, image 2 de 2
    • Use the point of a spudger to lift up the locking flap on the proximity sensor ZIF connector.
    Demander à FixBot
  49. HTC Vive XR Elite Proximity Sensor Replacement: étape 49, image 1 de 2 HTC Vive XR Elite Proximity Sensor Replacement: étape 49, image 2 de 2
    • Use tweezers to pull the proximity sensor cable out of its slot in the motherboard.
    Demander à FixBot
  50. HTC Vive XR Elite Proximity Sensor Replacement, Remove the proximity sensor: étape 50, image 1 de 1
    • Remove the proximity sensor.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
238 748 Réputation
1 171 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 930 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 46
Total : 376
