Aller au contenu principal
HTC Windows Phone 8S Logic Board Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: étape 1, image 1 de 3 HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: étape 1, image 2 de 3 HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: étape 1, image 3 de 3
    • Switch off the phone.
    • Remove the SIM / memory card cover.
    • Remove any SIM and memory cards.
    • Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
  2. HTC Windows Phone 8S Logic Board Replacement: étape 2, image 1 de 3 HTC Windows Phone 8S Logic Board Replacement: étape 2, image 2 de 3 HTC Windows Phone 8S Logic Board Replacement: étape 2, image 3 de 3
    • Use a plastic tool and slowly separate the back cover.
    • The loudspeaker is inside on the back cover.
  3. HTC Windows Phone 8S Logic Board Replacement, Battery: étape 3, image 1 de 3 HTC Windows Phone 8S Logic Board Replacement, Battery: étape 3, image 2 de 3 HTC Windows Phone 8S Logic Board Replacement, Battery: étape 3, image 3 de 3
    • Use a Phillips #0 screwdriver and remove the 4x silver screws.
    • With a plastic tool carefully separate the battery from the logic board.
  4. HTC Windows Phone 8S Logic Board Replacement: étape 4, image 1 de 3 HTC Windows Phone 8S Logic Board Replacement: étape 4, image 2 de 3 HTC Windows Phone 8S Logic Board Replacement: étape 4, image 3 de 3
    • The battery connector is under the middle frame. Remove it and disconnect the battery.
    • Model: BM59100 / 3,8VDC / 1700mAh
  5. HTC Windows Phone 8S Logic Board Replacement, Flex Cables: étape 5, image 1 de 3 HTC Windows Phone 8S Logic Board Replacement, Flex Cables: étape 5, image 2 de 3 HTC Windows Phone 8S Logic Board Replacement, Flex Cables: étape 5, image 3 de 3
    • Remove the USB dock connector metal plate.
    • Open flex cable connectors:
    • LCD display flex cable
    • Menu buttons flex cable
    • Volume buttons flex cable
    • Touch screen flex cable
    • Power button flex cable
    • Pick up the vibrating motor and take out all flex cables except the LCD display flex cable.
  6. HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: étape 6, image 1 de 3 HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: étape 6, image 2 de 3 HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: étape 6, image 3 de 3
    • The logic board is secured to the display frame by two locking clips.
    • Use a plastic tool to release it.
    • Now remove the LCD display flex cable from its connector.
  7. HTC Windows Phone 8S Logic Board Replacement, Logic Board / Main Board: étape 7, image 1 de 2 HTC Windows Phone 8S Logic Board Replacement, Logic Board / Main Board: étape 7, image 2 de 2
    • HTC Windows Phone 8S Logic Board.
ZFix
Membre depuis le 12/09/13
191 079 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 506 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 1,024
