Introduction
This guide will explain how to install / remove the keypad from the HTC Wizard 200.
Ce dont vous avez besoin
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Outil utilisé dans cette étape :T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use a screwdriver to remove eight 2mm Phillips screws that secure the keypad to the keyboard slider.
